UDP protocol being used. Absolutely stable in my office and around it. Go to an area where there is metal ducting and metal mezzanine upper floor and problems start. Colleagues esp has no issue in the same area.
In this area, the ap will start with signal level around -30dB, but will not allow a connection, then the signal will disappear, maybe re appearing some 10 seconds later, but still no connection allowed.
Thought it was an auto connect issue so that was disabled, but did not help.
Move to a different area and the signal / connection is stable again.
I could understand it if this was common problem area, but it appears not.
If the board layout invited pin rf saturation then this would not relate to the siting.
I'm going to try different channels, and also an esp7 with the crystal antenna, along with trying an external antenna and will eventually solve it, but if anyone has any thoughts on this, I would welcome any suggestions.
Thanks .....
