- Thu Jun 09, 2016 8:09 pm
#48895
Hi, I have this ESP8266 board:
http://linksprite.com/wiki/index.php5?title=LinkNode_D1, and I'm trying to make it work with this shield:
http://www.tinyosshop.com/index.php?route=product/product&product_id=464. It works fine with this smaller one which uses the same module:
http://www.ebay.ca/itm/New-SIM900A-V4-0-Kit-Wireless-Extension-Module-GSM-GPRS-Board-Antenna-Tested-FE-/331634149190. This leads to me believe that there is no reason why it shouldn't work and yet I am having issues communicating with the shield or making it work with the provided library (which works fine on Arduino). I doubt that I will be lucky enough that anyone reading this will have experience with this specific board and shield, so I guess what I'm asking for is general guidance on using shields with the ESP8266, what are common sources of problems and things to keep in mind while I struggle to get these things working together. Thanks a lot!
EDIT: I get this stack dump when I try to run the code, what can be the cause of this?
Code: Select allSoft WDT reset
ctx: cont
sp: 3ffeff40 end: 3fff01a0 offset: 01b0
>>>stack>>>
3fff00f0: 3ffe84c4 00000005 3ffeee64 4020209f
3fff0100: 0000001c 00000004 00000000 40201f34
3fff0110: 00000064 3ffe85c0 00000005 3ffeef50
3fff0120: 000000ff 00000012 3ffeee64 3ffeee64
3fff0130: 3ffe84c4 00000002 3ffeee64 4020209f
3fff0140: 3ffe84c4 00000003 3ffeef50 40202416
3fff0150: 00000960 3ffeee68 3ffef0c4 4020324c
3fff0160: feefeffe feefeffe 3ffef0c4 3ffef178
3fff0170: 3fffdad0 00000000 3ffef0c4 40201c3f
3fff0180: 3fffdad0 00000000 3ffef170 402036cc
3fff0190: feefeffe feefeffe 3ffef180 40100718
<<<stack<<<
