I recently purchased 3 ESP8266-01 to learn how to use them and, following several online tutorials, I installed the latest firmware. However, all three devices respond the same way when using ESP-Explorer:
Communication with MCU established.
Can't autodetect firmware, because proper answer not received (may be unknown firmware).
Please, reset module or continue.
2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 29824, room 16
tail 0
chksum 0x0b
load 0x3ffe8000, len 3064, room 8
tail 0
chksum 0xc3
load 0x3ffe8bf8, len 8, room 8
tail 0
chksum 0xa5
csum 0xa5 I used NODEMCU flasher and the latest bin file (nodemcu_integer_0.9.6-dev_20150704.bin). All three devices updated correctly (config used: Baudrate 115200 Flash size 4MB Flash Speed 40MHz SPI Mode DIO).
Having that said, I’m not sure where to go from here since none of the 3 devices are responding to the AT test.
Any help is appreciated.
TIA
