As I underatand, e.g. in this example:
http://41j.com/blog/wp-content/uploads/ ... _front.png
I need to use vias for GND und er the centre of the IC. Can i instead connect the GND plane oft the IC to a GND pin ?
THX
Thorsten
Explore... Chat... Share...
