I've designed this circuit which includes a TP4056 lithium charging board. The idea is to use this circuit to power the ESP12 by solar panel through the TP4056. At the same time I'd like this setup to still work to power the device if there's no solar power available (cloudy).
When testing this circuit with a solar panel connected or alternatively an external psu connected, the ESP12 boots fine but the problem I have at the moment is I don't seem to be able to get the ESP12 to boot from battery power alone. The lithium cell I'm using is a single 18650 cell which I believe is in decent shape / is holding a charge and is charged to around 3.9v.
This is all setup and being tested on a pcb at the moment but having gone back to my stripboard prototype I've now realized the problem exists there too so it seems I might have something wrong in the circuit. There's something common between the pcb design and the prototype setup causing this problem at least.
Can anyone see anything obviously bad with my schematic?
Thanks for any help
Joe
