I'm searching for this topic on Google since a few days with very poor results so I'm asking here, hoping that this is not a common question.
I am planning to use an ESP12F module to send data via WiFi from a gyroscope/accelerometer, and I need the system to be very light and compact, so I got some 350mAh LiPO battery packs. These output a different voltage (from 4.2 to 2.something) according to their charge level, which is of course not good for the ESP.
Therefore I am looking for a voltage regulator able to step up or down the input voltage while always giving 3.3V as output.
Most of the regulators I found have a ~1V or more droput, so they require at least 4.3V as input which is not good for me..
Does anyone know if there is some component or configuration that can achieve what I am looking for at a decent cost? I will need 5-10 of those, so it would be quite ridiculous to spend 10 times the cost of an ESP
tl;dr: looking for a voltage regulator with stable 3.3V output and from 2 to 5V as input with a suitable output current for an ESP12F module.
Please ask if I was not clear about something, I have decent programming skills but I am an amateur when it comes to electronics.
Thank you!
