I am a complete n00b to NodeMCU so please bear with me.
I recently received a new HiLetgo NodeMCU dev board and attempting an initial connection over USB (board placed on a blank breadboard and connected to the mini-USB cable).
I first connected the board to my PC's USB port. Windows detected the CP2102, auto-installed the Silicon Labs USB to UART Bridge driver, and presented a COM port.
I then opened Arduino IDE, set it up for esb8266/NodeMCU 1.0, selected the new COM port and attempted to upload the blink example. The result was:
warning: espcomm_sync failed
error: espcomm_open failedI tried different baud rates, USB ports, mini-USB cables, another Windows PC, but result is always the same. Serial Monitor is also blank and no commands are accepted.
I then set up my Mac with the ESPtool and installed the driver, connected the NodeMCU (/dev/cu.SLAB_USBtoUART is available), and attempted:
$ esptool.py -b 9600 --port /dev/cu.SLAB_USBtoUART flash_idoutput is:
esptool.py v1.3
Connecting...................
A fatal error occurred: Failed to connect to ESP8266: Timed out waiting for packet headerSo my guess is that while the UART is functioning, the ESP module is not responding.
Also when I hook up the module to USB, device is detected by Windows and LED behavior is in one of two states:
1. No LEDs are ever on or blink
2. A very faint red LED is lit (next to the voltage regulator)
Not sure what else to try at this point. Is it possible I am dealing with a DoD board?
Thank you
