By henkoegema
#63283 I have an ESP8266-1 as webserver.
Connected to GPIO2 is a LED which I can switch on and off via web.
When I power off the ESP it will not start correct as long as the LED is connected. :roll:
When I restart without the LED connected to GPIO2 and connect the LED after power is restored than it works ok. :)
By henkoegema
#63288
schufti wrote:let me guess !! .... you connected the led between gpio2 and gnd !!
You guessed correct.
schufti wrote:connect it between Vcc and gpio2 and .... experience another miracle !!
I'm going to try.
But what could be the reason that the way I did it is not working? (b.t.w. On the ESP8266-12E I don't have this problem.)
schufti wrote:(don't forget the resistor and to invert your logic)
By henkoegema
#63295
schufti wrote:......................................
I have reversed the LED. ( GPIO2 -> resistor -> LED -> VCC)
Changed pinMode(2, OUTPUT) to pinmode(2, INPUT)
But after that I'm not sure what to do. :?:
    * This sketch demonstrates how to set up a simple HTTP-like server.
    * The server will set a GPIO pin depending on the request
    * http://server_ip/gpio/0 will set the GPIO2 low,
    * http://server_ip/gpio/1 will set the GPIO2 high
    * server_ip is the IP address of the ESP8266 module, will be
    * printed to Serial when the module is connected.
    const char* ssid = "Sitecom438xxx";
    const char* password = "ABCDEFGH";
    // Create an instance of the server
    // specify the port to listen on as an argument
    WiFiServer server(80);
    delay(10);
    // prepare GPIO2
    // pinMode(2, OUTPUT); <---Commented out by me !!
    // digitalWrite(2, 0); <---Commented out by me !!
    // prepare GPIO2
    pinMode(2, INPUT); <----Changed this value from OUTPUT to INPUT
    // Connect to WiFi network
    Serial.println(ssid);
    WiFi.begin(ssid, password);
    Serial.print(".");
    Serial.println("");
    // Start the server
    server.begin();
    // Print the IP address
    if (!client) {
    return;
    //Serial.println("new client");
    while(!client.available()){
    delay(1);
    Serial.println(req);
    client.flush();
    // Match the request
    int val;
    if (req.indexOf("/gpio/0") != -1)
    val = 0;
    else if (req.indexOf("/gpio/1") != -1)
    val = 1;
    else {
    //Serial.println("invalid request");
    client.stop();
    return;
    // Set GPIO2 according to the request
    digitalWrite(2,0 ); <----- How to handle this here ?
    client.flush();
    // Prepare the response
    //String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
    //s += (val)?"high":"low";
    //s += "</html>\n";
    // Send the response to the client
    //client.print(s);
    delay(1);
    //Serial.println("Client disonnected");
    // The client will actually be disconnected
    // when the function returns and 'client' object is detroyed
