I am working on a motion anklet and am considering using the ESP8266-03 board to transmit 4-5 bytes at a time (once a minute at most). An arduino will process motion data and if data corresponds to a triggered pattern, data will be sent. The anklet will be using the following components:
Arduino Micro (5V)
1200 mAh Battery (3.7V, 500mA max discharge rate)
3.3V 300mA Linear Voltage Regulator
Adafruit 9-DOF IMU
I have heard/read that the Arduino Micro can't supply enough current during peak power consumption. I am thinking of connecting the battery to the voltage regulator and powering the ESP8266-03 module that way. Is that the most sensible solution for powering the both the arduino and the WIFI module?
I appreciate the help!
