- Tue Sep 26, 2017 6:12 pm
#70332
Hi
Yes i do. These are the settings.
Board: WeMos D1 R2 & mini
Flash size: 4M (3M SPIFFS)
CPU Frequency: 80 Mhz
Upload Speed: 921600
Port: /dev/cu.wchusbserial1410
I have been able to flash code to WeMos with these settings. I tested the blink example and it works fine.
This is the arduino-dw1000 code which i am trying to flash:
Code: Select all/*
* Copyright (c) 2015 by Thomas Trojer <thomas@trojer.net>
* Decawave DW1000 library for arduino.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
* @file BasicConnectivityTest.ino
* Use this to test connectivity with your DW1000 from Arduino.
* It performs an arbitrary setup of the chip and prints some information.
* @todo
* - move strings to flash (less RAM consumption)
* - make real check of connection (e.g. change some values on DW1000 and verify)
#include <SPI.h>
#include <DW1000.h>
// connection pins
const uint8_t PIN_RST = 0; // reset pin
const uint8_t PIN_IRQ = D1; // irq pin
const uint8_t PIN_SS = D8; // spi select pin
// DEBUG monitoring
Serial.begin(9600);
// initialize the driver
DW1000.begin(PIN_IRQ, PIN_RST);
DW1000.select(PIN_SS);
Serial.println(F("DW1000 initialized ..."));
// general configuration
DW1000.newConfiguration();
DW1000.setDeviceAddress(5);
DW1000.setNetworkId(10);
DW1000.commitConfiguration();
Serial.println(F("Committed configuration ..."));
// wait a bit
delay(1000);
// DEBUG chip info and registers pretty printed
char msg[128];
DW1000.getPrintableDeviceIdentifier(msg);
Serial.print("Device ID: "); Serial.println(msg);
DW1000.getPrintableExtendedUniqueIdentifier(msg);
Serial.print("Unique ID: "); Serial.println(msg);
DW1000.getPrintableNetworkIdAndShortAddress(msg);
Serial.print("Network ID & Device Address: "); Serial.println(msg);
DW1000.getPrintableDeviceMode(msg);
Serial.print("Device mode: "); Serial.println(msg);
delay(10000); // wait a bit
Thanks
S
