First of all, I have a PCB has ESP8266 on it and I can say the problem is not related about any GPIO high, low issue and schematic. Because I used the same PCB so many times and it is working.
I bought new modules (22 piece) and I have the same problem all of them.
The problem is, I can flash the NODEMCU or AT firmware successfully however, after reset module is not starting. I couldn't get any response. ESPLORER couldn't detect the firmware. I am only seeing unknown characters on the bus.
I have a copied image from my old ESP8266 modules and even this backup is not working. If I write this backup to my old modules, they are working like a charm without any problem.
So, what could be the problem of this new modules? If I couldn't find a solution I have to buy 22 more :/
Device parameters (NEW ONE - not working:
Manufacturer: 68
Device: 4014
Detected flash size: 1MB
Chip ID: 0x00ba837aDevice parameters (OLD ONE - working:
Manufacturer: e0
Device: 4014
Chip ID: 0x00fa29cfCMD output:
....esptool-master> python esptool.py -p COM8 write_flash 0x0000 .\firmwares\nodemcu-1.5.4.1-final-11-modules-2019-06-02-00-23-03-float.bin
esptool.py v2.3-dev
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266EX
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 1MB
Flash params set to 0x0020
Compressed 465060 bytes to 302984...
Wrote 465060 bytes (302984 compressed) at 0x00000000 in 26.9 seconds (effective 138.3 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...As you can see from top, I can read the module parameters in boot mode. There is no any problem to reading and writing to the memory. But, chip is not starting. Please give me an idea.
