By Magdici Emanuel
#86011 Hello,
It may be trivial to her, but I still find myself in trouble in this area. I'm trying to read the data from an M-Bus flowmeter, after many tests and hairs I decided to put a signal analyzer on Tx and Rx immediately after power
Rx = D0 & Tx = D1
- https://ibb.co/c3nZTKp
And if I connect the same flow meter through the same converter but
not with the ESP8266, I connect to USB TTL everything is fine
- https://ibb.co/XsqvLjr
Are there any ideas why and how this problem can be solved :?:
