I'm writing software to control a series of RGB LEDs that includes cool features such as fading, pulsing, changing colors, etc all based off of a JSON string sent via UDP.
Anyway the whole project has gone smoothly up until I started to update the SDK versions. Ar first I couldn't pulse/change the color of the LEDs too quickly since the old PWM code in 0.9.4 took too long to run pwm_start(), so I started to update. The new PWM code is a lot of efficient, and allows me to fade much quicker.
The only problem is that with the new SDK I am running into two different issues. Either my timers fail to go off after a certian period of time, or the watchdog kills the system.
If I disable the watchdog using system_soft_wdt_stop() or ets_wdt_disable(), then the system will stop receiving packets. It no longer responds to any packets or commands after an extended length of time.
If I keep the watchdog enabled by feeding it and running system_soft_wdt_stop() and system_soft_wdt_restart() on long sections of code, the system stops my timers from going off after a certain period of time. On wits end, I have one timer going off every three seconds, feeding the dog and printing a statement. After 105 seconds the timer stopped going off and I noticed after a while this appeared on the UART:
why 102400 1 123855715 972612494
rm 0
pm close 7 0 0/968881879
reconnect
f 0, Current wifi state 1
scandone
add 0
aid 1
pm open phy_2,type:2 0 0
cnt Then my device restarted my code, but it wasn't a wdt_reset. Any idea?
If I feed the device properly, sometimes the device will stop scheduling my timers. For example, at one point I was printing a string right before the disarm, arm, etc for a timer. I would see the device print that line and the code for the timer would never run. It would force a restart.
So my main question is three fold, how can I convince the ESP8266 to stay alive with the espconn listening with the watchdog restarting every time I stop running code? Or how can i have my timers go off with the watchdog disabled? Or how can I keep the watchdog happy with how I have this code setup?
Or rather can I find example code that keeps the wdt timer happy? I don't quite understand how I am supposed to lay out my code so that the system doesn't think my code is stuck. I can run someone through the layout of my code, but I feel that I've made this post long enough.
Appreciate the insight guys. This embedded system is the most fun I've had in a while.
