I've no UART tool so I'm using an Arduino Mega ADK as bridge connected using a level shifter.
When I use the esptool.py tool for flashing the new firmware it stops during the initial sync phase.
Looks like the ESP is not responding.
I've tried with the Serial monitor too see what it send when it boots and I got the following results:
- When I wire GPIO 0 to GND and GIO 2 to Vcc, after a reset I get this string:Code: Select all
ets Jan 8 2013,rst cause:2, boot mode:(1,7) - When I wire GPIO 0 to Vcc and GIO 2 to Vcc, after a reset I get this string:Code: Select all
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
ets_main.c
In both modes when the esptool sends the SYNC op the ESP seems not responding.
Any idea?
