- Tue Jul 21, 2015 3:50 am
#23799
I've some of those and use them without a regulator. I like them, not least beacuse they're so cheap. The most common complaint about this board is its so wide that they're not so easy to use with a breadboard as they cover all the holes. What i do is use header pins longer than the board and as the VCC and GND are both at one end you can then short all the extra pins together and connect to the supply rails and then for simple prototyping you often don't need to use a breadboard -
(that one also has a couple of capacitors across the supply, i think the 100nf one probably isn't necessary as someone said there already is one under the ESP12s metal cover)
