I am interested in alkaline batteries and non-rechargeable lithium batteries.
Explore... Chat... Share...
Amber wrote:You can use 4 aa batteries. A 9 volt battery gets drained too fast.
helpme wrote:Amber wrote:You can use 4 aa batteries. A 9 volt battery gets drained too fast.
Why 4? Wouldn't 2 AA batteries be enough? 2AA gives 3V, then use boost regulator to boost to 3.3V.
If use 4 batteries, how would you arrange the batteries? In series or parallel or both?
