By Antaras
#35002 hello i am new with the ESP8266 and i don't have any idea !!!
Yesterday came my order with 3x ESP8266 i try to connecting with much different ways but nothing happened !!
i am 101% sure i have the correct connection but i don't take any answer from the arduino !!
i have see the pcb soldering is little bit strange... is this soldering right ??
its same all 3 smell like CHINA :P
Thank you !!!
By Antaras
#35038
martinayotte wrote:Although those solderings look bad, the modules maybe working any way.
When you try them out thru your Arduino, did you sent AT commands follow with CR+LF, not only CR ?
Thank you for your answer !!
Both don't work..
When I connect it to the arduino I don't take nothing like " ready " or other answer from board..
:cry:
By Barnabybear
#35042 Hi, with some of the Arduinos the Tx and Rx are the connection that you should connect to, not the names of the pins.
With most other stuff:
Tx -> Rx
Rx -> Tx
With some Arduino:
Tx -> Tx
Rx -> Rx
As if life wasn't hard enough without complications. See if that helps.
