However, the only place I find that is on the UART.
Has anyone tried to change the configuration on other GPIO pins?
Nothing in user_plug.c but the macros do show up in uart.c.
Please refer to \user\ user_plug.c。
5.1.1. PIN setting macro
PIN_PULLUP_DIS(PIN_NAME)
Disable pin pull up
PIN_PULLUP_EN(PIN_NAME)
Enable pin pull up
PIN_PULLDWN_DIS(PIN_NAME)
Disable pin pull down
PIN_PULLDWN_EN(PIN_NAME)
Enable pin pull down
PIN_FUNC_SELECT(PIN_NAME, FUNC)
Select pin function
Example:PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDI_U, FUNC_GPIO12);
Use MTDI pin as GPIO12。
