By hooyacrusty
#40371 Hi,
I apologize if this problem has a solution somewhere in these forums, but I haven't been able to find it. I'm new to ESP8266 and have been playing around with an ESP8266-01 I bought off of ebay. It seemed to be working fine until I attempted to change the baud rate to 9600 when I was trying to make it work with Arduino SoftwareSerial. That actually did work, but for some reason after powering everything off (and back on again), it doesn't respond to AT commands at any baud rate. Also, I've tried using the flash updater program in Windows 8.1 via a 3.3V FTDI USB adapter, but that only responds with "Failed to connect." The odd thing is if I reset the 8266 while connected at 74880 I can see that's it's booting up fine. I can also see it in the list off available wifi networks and I can connect to the AP. I've tried powering it directly from an 300w ATX power supply so that can't be an issue. Any help would be much appreciated.
By hooyacrusty
#40418 More info. When I reset the ESP it responds with this:
Code: Select all ets Jan  8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 1396, room 16
tail 4
chksum 0x89
load 0x3ffe8000, len 776, room 4
tail 4
chksum 0xe8
load 0x3ffe8308, len 540, room 4
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 40MHz
  SPI Mode       : DIO
  SPI Flash Size & Map: 8Mbit(512KB+512KB)
jump to run user1 @ 1000
do  <<garbage charachters here>>
SDK <<more garbage>>
Also, the firmware updater is ESP8266_flasher_V00170901_00_Cloud Update Ready
