Assuming that I have a clean 5v regulated supply being further LDO regulated down to 3.3v for an ESP12, from what I read here and in other places it seems to be recognized good practice to include decoupling capacitors on the 3.3v supply to stabilize and filter the supply. I do have 0.1uF and 47uF capacitors available to use and a range of smaller than 0.1uF and greater that 47uF caps available to me.
So far as I can tell, the larger capacitor is usually placed near the 3.3v source and the smaller capacitor is ideally placed right next to the ESP Vcc in and ground pins.
Right now I have no other components connected to my ESP12 other than an occasionally connected TTY/USB convertor for programming and my question: is using a 47uF cap going to be safe to use or is this too large? In addition to that I guess a more general question is: are large capacitors bad for the life expectancy of an ESP8266 board / how is correct capacitance calculated for a circuit?
Please be gentle - as you can see I'm obviously a bit clueless with electronics
Thanks for any help
Joe
