- Fri Nov 07, 2014 12:40 pm
#2313
phil31 wrote:what i can suggest instead of start from scratch is to "simply" do the same AT set .. then the documentation will be already write
I have also worked with Microchip command set, but it does not map very well (not
simply at least) on the API provided by Espressif. But if you do see a good way to do that, you are welcome to contribute an implementation of a different 'flavour' of AT command set.
phil31 wrote:maybe on your http://th.igrr.me/ page (binaries version) you can add the date of the build ? because the actuel revision "3be7f3c" is not easily readable !
Thanks for the tip. Will add the build date.
phil31 wrote:is it possible to provide a single BIN file to flash instead 2 or more with offset settings ?
This was requested
on github and @picstart1 had similar issues earlier in this thread. Will look into this early next week.
