Before after changing the baud rate to 115200 the firmware would fail generating framing errors...with the latest bin this issue has gone away.
Thanks grr
Explore... Chat... Share...
AT+CIPSENDI=0,"first 250 bytes"
OK
+CIPSENDI:0
AT+CIPSENDI=0,"second 250 bytes"
OK
+CIPSENDI:0
dce = dce_init(256);
dce = dce_init(1600);
