can you post a full example about using A6 with esp8266 ( wiring, code , library)
thank you
Explore... Chat... Share...
stern0m1 wrote:Im having issues communicating via the serial ports between the a6 gsm module and the esp8266.
Are the serial ports compatible? Both are supposed to operate at 3.3v. Are there some settings I need to configure.
I am able to communicate with the a6 gsm just fine with a terminal.
Thanks
