Now, this morning, i did some fast tests on wemos nodemcu 3.0 and looks that it´s working, not reset during run, reset or power up.
But i didnt connected the lcd in this module yet.
The older module was nodemcu 1.0.
Let me know if your test works (havoc).
And try to reduce the SPI speed for a while!
Miguel
lpservices wrote:Hello,
I am using a D1 Mini NodeMCU Lua ESP8266 ESP-12 WeMos D1 Mini WIFI 4M Bytes
In the Adafruit library I noticed that bitmaps can be scaled by an integer,
Since espbasic only uses scale=1, I eliminated the extra code,
The code runs a bit faster now, but still craches
Maybe because the transfer are now a bit faster, the breadboard is playing havoc to the signals/power supply,
I will try to remove from breadboard and use seperate power supply for the display
Will keep you posted
regards,
-lpservices
