When trying to print floating point numbers I get no output. Also, when trying so sprintf a float no conversion takes place. Is there a floating point library and if there is how do I enable it?
Thanks!
Explore... Chat... Share...
#define DEC_PLACE_MULTIPLIER 10000
char * print_float_voltage(double d_voltage) {
int32_t voltage = d_voltage * DEC_PLACE_MULTIPLIER;
os_sprintf(buf, "V = %d.%04u", voltage / DEC_PLACE_MULTIPLIER, abs(voltage) % DEC_PLACE_MULTIPLIER);
return buf;
}It takes about 20-25 seconds for home assistant c[…]
