I have been scouring the internet and have came up empty handed. I have an ESP-01 where I made a project to read a temp sensor and post to my mqtt broker. The program worked great after some tweaking and now I am trying to include a light sleep. I am unable to do deep sleep since I don't have access the the required pin (tried on one and ended up pulling a pad
I have successfully deployed the light sleep and the current drops to uA but I have this error popup when I try to wake and re-initialize wifi.
After a few tries and an error (is it reporting what is stored in the buffer?) it reconnects, sends the temp and continues on. After about 3-5 cycles of this, it finally errors out and stops running all together. It appears that wifi drivers are still asleep? I am not sure if channel refers to trying to connect to the scanned channel found or something else. I am using channel 11 on my router. I tried adding de-init to no success. Did not find any information on needing to wake up things once timer was done.
For the wifi init I am using the example code. Here is everything else I got in regards to sleep:
printf("MQTT CONNECT\n");
printf("MQTT SEND DATA\n");
mqtt_app_start();
printf("STOP MQTT\n");
mqtt_disconnect();
printf("STOP WIFI 2\n");
ESP_ERROR_CHECK(esp_wifi_disconnect());
ESP_ERROR_CHECK(esp_wifi_stop());
// ESP_ERROR_CHECK(esp_wifi_deinit());
printf("START TIMER\n");
sleep_mode();
printf("START wifi\n");
ESP_ERROR_CHECK(esp_event_loop_delete_default());
wifi_init_sta();
mqtt_connect();
Sleep function:
void sleep_mode() {
esp_sleep_enable_timer_wakeup(TIMER_WAKEUP_TIME_US);
ESP_ERROR_CHECK(esp_light_sleep_start());
printf("WAKEUP!\n");
vTaskDelay(pdMS_TO_TICKS(1) / portTICK_RATE_MS);
I (2238) tcpip_adapter: sta ip: 192.168.7.133, mask: 255.255.255.0, gw: 192.168.7.1
I (2242) wifi station: got ip:192.168.7.133
I (2246) wifi station: connected to ap
I (2253) system_api: Base MAC address is not set, read default base MAC address from EFUSE
I (2268) MQTT_EXAMPLE: Other event id:7
MQTT CONNECT
MQTT SEND DATA
I (2296) MQTT_EXAMPLE: MQTT_EVENT_CONNECTED
STOP MQTT
I (4061) MQTT_CLIENT: Client asked to disconnect
STOP WIFI 2
I (4213) wifi:state: 5 -> 0 (0)
START TIMER
WAKEUP!
START wifi
I (10531) system_api: Base MAC address is not set, read default base MAC address from EFUSE
I (10536) system_api: Base MAC address is not set, read default base MAC address from EFUSE
I (10549) wifi station: wifi_init_sta finished.
set channel in sleep mode, fail and exit
I (12593) wifi station: retry to connect to the AP
I (12596) wifi station: connect to the AP fail
E:RX 16b
rxbufbit:ffff
E:AC 1, 33, 52
CONF:b00b, PLCP:632da0, rf:50000000, rx:0,0, tx:10000
I (14652) wifi station: retry to connect to the AP
I (14655) wifi station: connect to the AP fail
I (14773) wifi:state: 0 -> 2 (b0)
I (14774) wifi:state: 2 -> 3 (0)
I (14776) wifi:state: 3 -> 5 (10)
I (14788) wifi:connected with Garden, aid = 5, channel 11, HT20, bssid = 68:72:51:7e:7b:c6
I (16534) tcpip_adapter: sta ip: 192.168.7.133, mask: 255.255.255.0, gw: 192.168.7.1
I (16538) wifi station: got ip:192.168.7.133
I (16542) wifi station: connected to ap
W (16549) event: handler already registered, overwriting
I (16558) MQTT_EXAMPLE: Other event id:7
MQTT CONNECT
MQTT SEND DATA
I (16592) MQTT_EXAMPLE: MQTT_EVENT_CONNECTED
STOP MQTT
I (18356) MQTT_CLIENT: Client asked to disconnect
STOP WIFI 2
I (18437) wifi:state: 5 -> 0 (0)
START TIMER
Appreciate any guidance.
