After connecting the ESP8266 (01) module to Arduino UNO, I tried to scan for nearest network present [code link: https://github.com/esp8266/Arduino/blob ... imple-scan] and it worked perfectly.
But the moment I am trying to connect to send AT commands (even manually) it shows nothing. I have flashed the code to the ESP-01 (using the Arduino as a serial port adapter).
Now, while reprogramming the 'AT' firmware into the ESP, it used the same Program Address Offset [Hex] value for firmware [0x000000] that my Arduino (*.ino) code uses while code is compiled and uploaded. I am trying another range with no result. Can you tell me how to change the Program Offset for Arduino [0x000000]. Any able comment is solicited.
