By rudy
#74397
Is it OK to leave the unconnected pins floating?
It is a good practice to enable the pull up resistors on a pin that is left floating. That or setting the pin as an output.
If the pin is left floating it can be at a state where it is seeing transitions. Usually that is not too big a problem but it would have to get a proper answer if it matters would mean getting information about it from the chip manufacture. It is just easier to do one of the two methods I stated.
By btidey
#74403 Yes, good idea to explicitly set unused pins to INPUT_PULLUP.
The chip itself defaults the pins to INPUT_PULLUP after reset but if using the Arduino environment then that sets them back to INPUT as part of its initialisation code. That is a bit irritating, it would be better to init them to INPUT_PULLUP.
GPIO16 doesn't have INPUT_PULLUP, but can be set to INPUT_PULLDOWN_16
By schufti
#74406 and please don't just use resistor between gpio16 and rst. This is not a clean method, especially if one wants to use rst external too. Replace yor 100Ohm resistor by any small schottky diode (cathode towards gpio16).
reason: gpio is strong high during deepsleep, so will rst be with 100Ohm resistor and any flashing circuitry (appart from plain push-button) will have to work against this strong high when trying to reset (pull rst low) the esp.
