I bought some DoIT modules from Aliexpress and have experienced nothing but frustration.
I'll focus on the "NodeMCU" module. I plug it into the usb, I see a ch340 in device manager on COM4 (or 5 or 6 depending on USB port).
I open Arduino IDE1.8.6, I select either the .9 or the 1.0 NodeMCU. This is listed for an esp-12 but it's the only one that sort of responds. I select a sketch, any sketch, doesn't matter. The IDE says it's writing but I can't see any activity on my module, only a solid red led.
I'm so frustrated, what am I missing? I've held flash down during the entire process. I've depressed flash on power up, held down, pressed and released reset, then released flash button.
no matter what I do, all I can get it to say, and this is after I press the reset button, is this:
21:14:37.835 ->
21:14:37.835 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
21:14:37.836 ->
21:14:37.836 -> load 0x4010f000, len 1384, room 16
21:14:37.836 -> tail 8
21:14:37.836 -> chksum 0xef
21:14:37.836 -> csum 0xef
21:14:37.836 -> csum err
21:14:37.836 -> ets_main.c
I've found thirteen different resources that state thirteen different methods. Nothing works. I've tried different com ports, every baud rate, every SPIFF setting, every sketch.
What am I missing?
