By gdsports
#76235 Each ESP must use a unique MQTT client name. mosquitto disconnects clients with duplicate names. In the current code, "ESP8266Client" is used for all clients.
Code: Select allif (client.connect("ESP8266Client", mqtt_username, mqtt_password)) {
See the latest pubsubclient ESP example which generates a random client name for every connection.
Code: Select all    Serial.print("Attempting MQTT connection...");
    // Create a random client ID
    String clientId = "ESP8266Client-";
    clientId += String(random(0xffff), HEX);
    // Attempt to connect
if (client.connect(clientId.c_str())) {
If the problem persists, turn on verbose debug on the MQTT server to see if and why it is disconnecting clients. Wireshark captures might be helpful.
By fritserasmus
#76338
gdsports wrote:Each ESP must use a unique MQTT client name. mosquitto disconnects clients with duplicate names. In the current code, "ESP8266Client" is used for all clients.
Thank you gdsports.
That was exactly what I needed.
