i took much care on power supply issues:
- i have used a separate regulator for up to 1A
- i have added a 6.8uF cap directly between the supply pins
- i think in this startup phase, the device has not yet activated the current hungry WLAN transmitter with+25dBm
You are also recommending to use an evalboard like nodemcu.
If i understood correctly, these are using the same 8266 hardware, why should this behave different and easier.
What is different?
Ok, for some trials i can buy a module, but at the end i will need a small module like ESP07 to add to my ready application.
Do you think, a new firmware download could help to overcome the issues, isn't the ESPmodule delivered with a suitable firmware loaded?
