By shiningthing
#91564
JurajA wrote:does the other side act as HTTP server?
https://arduino.stackexchange.com/quest ... 6899#66899
I don't think it works with HTTP. I've tried this code and winsock managed to send data to ESP8266. Do you have any idea to send data from ESP8266 to winsock (reverse direction)?
#define RX 3
const char* ssid = "XXX"; //SSID Access Point
const char* password = "123"; //Password Access Point
const char* host = "192.168.100.10"; //IP PC
//Client-ESP8266 IP Address
IPAddress IP(192,168,100,220);
IPAddress NETMASK(255,255,255,0);
IPAddress NETWORK(192,168,100,1);
IPAddress DNS(192,168,100,1);
WiFiServer server(180);
String sEncoded="";
String line="";
int bytes[256];
  Serial.begin(9600);
  delay(1);
   // Connecting to a WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  Serial.println("");
  server.begin();
   Serial.printf("\n[Connecting to %s ...", host);
   if (client.connect(host, 180)){
      Serial.println("connected]");
      while (client.connected() || client.available()){
        if (client.available()){
          line = client.readStringUntil('\n');
          Serial.println(line);
       //convert ascii to binary (not succeeded)
        for (int i=0; i<line.length(); i++){
          char character = line.charAt(i);
          for (int j=7; j>=0; j--){
            bytes[i]=bitRead(character,i);
            Serial.print(bytes[i]);
            if(bytes[i]==1){
              digitalWrite(RX, HIGH);
            else{
              digitalWrite(RX,LOW);
            delay(50);
      client.stop();
      Serial.println("\n[Disconnected]");
   else {
          Serial.println("connection failed!]");
          client.stop();
    delay(1000);
