By Bison
#92161 I'm having the same issue, and I suspect it has to do with not knowing the correct hex addresses to use.
The two terminal programs I use (Termite and PuTTY) both show the garbled data, and changing the baud rate doesn't seem to do anything but slow it down or speed it up.
I'm using the Flash Tool ver. 3.8.8 and the NonOS SDK ver. 3.0.4. The flash tool reports the following:
flash vendor:
20h : N/A
flash devID:
4016h
QUAD;32Mbit
crystal:
26 Mhz
The menu choices were set according to these, but I don't have a clue if I'm including all the required files or if they're being assigned to the proper locations. Help would be appreciated.
Thanks in advance
