I'm justing running the blink sketch under the generic esp8266 board configuration. The sketch upload fines but while running it will frequently restart with this :
Not sure if this is related to the capacitors or the voltage regulator. I'm using an HT7333 regulator, perhaps that isn't an appropriate one? What I witness is that if I check the voltage across the VCC (on the breakout)/GND it stays constant at like 4.9V, if I check the voltage across Vout of the ht7333 and GND its at 3.3 but then dips to under 2 as the resets occur.
Thoughts?
