With this I wont even need a power adapter right?
Explore... Chat... Share...
I had stumbled across the sonoff but didn't really take it serious (too good a deal?)
WosO wrote:I would like to create a wifi controlled realy. So far i'm considering a NodeMCU v2 + Relay + generic 5v Power adapter or a plain ESP8266 board + relay + serial adapter (would a raspberry pi 3b work for this?) + 3.3v Power supply.
It appears to me that the NodeMCU build would be slightly more expensive, but much more compact and simpler for a beginner. Is that assesment correct?
Would like to hear any and all suggestions to do this the "simplest" possible way.
Thanks for any advice!
