sudhanshuesp wrote:After i connect the module with a ftdi driver module, it does not works. the ftdi driver is set at 3.3 volt and the esp module is power by a 5 volt supply and a 3.3 volt regulator.
It seems he is not using the FTDI for the 3.3v Vcc.
@sudhanshuesp The second image is the schematic you used. It shows CH_EN being used for reset. This is acceptable, but it shows pin 1 (reset) not connected. Connect this to the reset switch or connect to Vcc.
You should be able to communicate with the module through AT commands. You do not need to program the module to do this. (once programmed the code for AT firmware is overwritten) If you still have problems then you should buy yourself a working development board. Get yourself running and then work with individual modules later.
As an example https://www.aliexpress.com/item/ESP8266 ... 89539.html
