By MartinS
#74707 It seemed like I had gotten a connection between DTR# and RTS# while soldering last time, removing that connection still didn't stop the ESP from resetting.
I soldered wires to DTR#, RTS#, GPIO0 and RESET and made the reset circuit from the NodeMCU schematic on a breadboard using BJT's instead of the MOSFET's on my PCB. I managed to successfully program the ESP again, but only once. Now it won't program anymore, and I get the same error as I did before:
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
Using a logic analyzer I see that the DTR# and RTS# lines don't respond when I try to program the ESP.
Back to debugging again...
By MartinS
#78743 I picked up this project again, and there were two errors on my schematic.
First of all, VIO was left floating, so my data-lines didn't get a reference voltage, tying VIO to VDD fixed this issue.
Second of all, the CP2102N needs a voltage divider on the voltage that goes into VBUS to function properly.
Adding these two fixes made the board function as intended, and I can program the ESP-module with ease.
