I just don´t feel sure with pins only boards
But will order a few ESP01 and a programming unit to test it out.
1) Is it ok to have the float switch between the positive wire?
2) is there a better way to cut off the power after the signal is sent? The float switch will keep power on for 1-3 days if not cut off. Plan to use this timer circuit.https://www.aliexpress.com/item/DC-3-12 ... 0.0.XM3Qpn
