https://wiki.wemos.cc/_media/products:d ... _motor.pdf
So I know that motors should have their own power, but could I get away with connectin Mini's 3V+GND to shield's VM + GND considering fact that my geared motors are 3V, 3rpm and they won't be moving at the same time? I will be powering it with USB so I would like to avoid additional battery to save space.
Thank you.
If you run into problems you could take the 5 volts, pass it through a couple of silicon diodes to drop the voltage, and feed that into the VM input. This might be your preferred method from the start.
