- the flash was created for that size and is referencing the wrong user_init and certificate flash locations
- the locations the OP used to flash the above were not correct for the larger flash size
Explore... Chat... Share...
softfoot wrote:The chip is a 25Q32 and is reported as 32Mb so I tried 32Mbit-C1 ---- on a reboot all I got out of the serial port was garbage.
In the end after going around in circles web searching and getting conflicting info on the meaning of the "-C1" I tried the 16Mbit-C1 settings and it worked!
So, my question is given my chip is a 25Q32 why on earth do I have to use 16Mbit-C1 ???
I think the 1.7 'prebuild' binaries are for 16Mbit flash,
and the esptool would flash it right with addresses for 16Mbit flash.
