RichardS wrote:I am not sure why they turn them off, you can try removing the interrupt off and interrupt on functions and see what happens, I would test a lot as it may cause issues on now and again.
I am sure someone else may know better, this is how I would approach it and see.Code: Select all
//noInterrupts();
if(spi_flash_erase_sector(_sector) == SPI_FLASH_RESULT_OK) {
if(spi_flash_write(_sector * SPI_FLASH_SEC_SIZE, reinterpret_cast<uint32_t*>(_data), _size) == SPI_FLASH_RESULT_OK) {
_dirty = false;
ret = true;
//interrupts();
RichardS
Thanks for the guidance RichardS. I already have check this method and it resets node-mcu and a unrecognizable error shows on serial monitor with weird exceptions and and numbers....
The good news is the problem has been solved by changing EEPROM Liberary to ESP_EEPROM Liberay https://github.com/jwrw/ESP_EEPROM ... Now it is working normally and storing the values as expected.
Thanks again for your cooperation.
