By jmattioni
#93280 OK, I've resolved my issue. The basic problem is that the level converter I'm using isn't designed to drive an input with a pull-up. The ESP8266 RX pin has a built-in pull-up holding it at 3.3v. I got around this by using a PNP switching transistor.
By UN26uxx
#93318
jmattioni wrote:OK, I've resolved my issue. The basic problem is that the level converter I'm using isn't designed to drive an input with a pull-up.
Good news, there is a way to deal with this.
jmattioni wrote:The ESP8266 RX pin has a built-in pull-up holding it at 3.3v. I got around this by using a PNP switching transistor.
Can you explain me more in details this ? Through a schematic if possible to be as clear as possible for everybody.
I'm not an expert with electronics. I already saw some pull-up or pull-down using a NPN transistor. But I'm not sure if it's the same or not. Honestly I tried to do some, but it wasn't working, it's possible I haven't plug it correctly.
