I try out these wiring scheme (NOT WITH 2 SOURCE OF POWER, ONLY ONE OF THE TWO REPRESENTED IN THESE IMAGE) and these sketch:
#include "SoftwareSerial.h"
SoftwareSerial Esp_serial(8, 9); // RX, TX
void setup()
//Dato che l'ESP, a seconda del Firmware, puoùò essere impostato a Baud Rate diversi
// scegliere quello corretto tra le due seguenti configurazioni
Esp_serial.begin(9600);
//Esp_serial.begin(115200);
// Impostazioni della porta per il serial monitor
Serial.begin(115200); // serial port used for debugging
void loop()
if (Esp_serial.available()) // check if the ESP is sending a message
while (Esp_serial.available())
int c = Esp_serial.read(); // read the next character
Serial.write((char)c); // writes data to the serial monitor
if (Serial.available())
// wait to let all the input command in the serial buffer
delay(10);
// read the input command in a string
String cmd = "";
while (Serial.available())
cmd += (char)Serial.read();
// print the command and send it to the ESP
Serial.print(">>>> ");
Serial.println(cmd);
// send the read character to the ESP
Esp_serial.print(cmd);
And I get these results
>>>> AT+GMR
AZ+GMR
AT vession:1.1.0/0(May 11 2006 18:09:56)
SDK versioo:1.5.4
ryn1
>>>> AT+GMR
AR¥TJÕ¨H(Q�²•ÉÍ¥½¹éŠrŠr‚r‚Bj…å�ŠŠ'‚Š²ŠÂÒ‚ÊÒª²Jj
SDK version:1.5/4(baaeaebb(
eo. O
>>>> AT+GMR
PÕ¥TJÕ¨H(Q�²•ÉÍ¥½¹éŠrŠrƒr‚Bj…å�ŠŠ"‚Š²ŠÂÒ‚ÊÒª²Jj
SDK vershon:1.5.4(ba`eaebb)
ild3:
>>>> AT+GMR
AR¥TJÕ¨H(Q�²•ÉÍ¥½¹éŠrŠr‚r‚Bk…å�ŠŠ'‚Š²ŠÂÒ‚ÊÒª²Jj
SDK version:0.5.4(baaeadbb)
TC12
I see the light at the end of the tunnel but i don't know comunication is not perfect
Can some one explain me what's happening?
Why the first command respond correctly than characters get mad?
