https://www.itead.cc/sonoff-wifi-wireless-switch.html
This is a "Newbie" forum the focus is working with the ESP8266 on the Arduino platform. It is not intended to explain how to work with AC line voltages.
Explore... Chat... Share...
Your response hasn’t answered my question - is the bulb powered by 5v?
If it is then you don’t need the separate 3.3 and 5v outputs from the power supply if you use a Wemos/NodeMCU ESP8266 Device, as these can be powered by 5v.
Pete.
rudy wrote:If someone does not have any experience working with lethal voltages then I strongly suggest using ready built modules like the following. These cost little and are a lot more convenient than building something.
