By agil
#65076 Hello,
I am interested in the esp8266 for working with a sensor in my home which sends data using 5MHz channel bandwidth on a standard 2.4GHz wifi channel.
I would like to know about the following:
1. is there a possibility to modify the esp8266 to communicate on a standard 2.4GHz channel but at a non standard 5MHz bandwidth?
2. If I have a 5MHz signal from the sensor which is centered on a standard channel, will the esp8266 be able to receive it and process it correctly?
Thank you in advance,
agil
