By Gert
#65672 Little simpel esp8266 arduino project with aREST and aRESU_U, it seems ok without problems, but after some times after the system has been turned off and turned on later, no connection to wifi can be created. A new upload is needed, then the same again, have an idea , Or is the esp8266 card that's not okay?
Kindly Gert
Sorry google english
By Gert
#65806 Thanks for the response, it works perfectly about 15 minutes. Then no contact to server (ip address)? Is it because the IP address changes on the esp / my router? No fixed IP address has been established? . Another card question: disappears the upload program after power off on esp ??
Please Gert
By atexit8
#65843
Gert wrote:Thanks for the response, it works perfectly about 15 minutes. Then no contact to server (ip address)? Is it because the IP address changes on the esp / my router? No fixed IP address has been established? . Another card question: disappears the upload program after power off on esp ??
Please Gert
If you remove power, then the IP address is lost.
