Any examples/pointers/advice gratefully received.
Explore... Chat... Share...
// Some LEDs and a relay. Lamp control end.
// parse packet
// UDP recieve packet. If "pwm\n" then send back current pwm value
// else use value received as integer for pwm update. range 0-1023
#include <WiFiUdp.h>
const char* ssid = "esp-net"; // your network SSID (name)
const char* pass = "123456789"; // your network password
//IPAddress relayIP = (192,168,100,118);
IPAddress relayIP = (192,168,100,101);
unsigned int localPort = 5000;
int status = WL_IDLE_STATUS;
char packetBuffer[255];
char ReplyBuffer[] = "OK\n";
int pwm = 0;
bool switch0State = 0;
const int switch0 = 0;
const int led2 = 2;
const int led12 = 12;
const int led13 = 13;
const int led14 = 14;
const int led15 = 15;
const int relay = 4;
WiFiUDP Udp;
void rxUDP() {
int packetSize = Udp.parsePacket(); //Checks for a UDP packet, and reports the size.
if (packetSize) {
IPAddress remoteIp = Udp.remoteIP();
int len = Udp.read(packetBuffer, 255); // read packet into packetBuffer
if (len > 0) {
packetBuffer[len] = 0; // reset length
if (strcmp(packetBuffer, "pwm\n") == 0) { // if packet "pwm\n"
char p[5];
String str = String(pwm);
str.toCharArray(p, 5);
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write(p); // current value for pwm
Udp.endPacket();
else { // make number into pwm for output 0-1023
pwm = atoi(packetBuffer);
Serial.print("pwm= ");
Serial.println(pwm);
analogWrite(led15, pwm);
// Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
// Udp.write(ReplyBuffer); // send 'OK\n'
// Udp.endPacket();
//--------------------- serial print details ----------
if (packetSize > 0)
Serial.println("----------------------"); //
Serial.print("packetSize=");
Serial.println(packetSize);
Serial.print("Data was -> ");
Serial.print(packetBuffer);
Serial.print(" <- From IP : ");
Serial.print(Udp.remoteIP());
Serial.print(":");
Serial.println(Udp.remotePort());
// Use a switch statement to examine the first character of the packet buffer
switch (packetBuffer[0]) {
case '1': //
digitalWrite(relay, HIGH);
break;
case '2': //
digitalWrite(relay, LOW);
break;
case '3': //
digitalWrite(led2, HIGH);
break;
case '4': //
digitalWrite(led2, LOW);
break;
case '5': //
digitalWrite(led13, HIGH);
break;
case '6': //
digitalWrite(led13, LOW);
break;
case '7': //
digitalWrite(led14, HIGH);
break;
case '8': //
digitalWrite(led14, LOW);
break;
pinMode(led2, OUTPUT);
pinMode(led12, OUTPUT);
pinMode(led13, OUTPUT);
pinMode(led14, OUTPUT);
pinMode(led15, OUTPUT);
pinMode(relay, OUTPUT);
pinMode(switch0, INPUT_PULLUP);
WiFi.begin(ssid, pass);
delay(100);
Serial.print(".");
Serial.println("");
Serial.print("IP: ");
Serial.print(WiFi.localIP());
Serial.print(":");
Serial.println(localPort);
Udp.begin(localPort);
rxUDP(); //check for input and process if available
delay(10);
if ((digitalRead(switch0)) != switch0State)
switch0State = !switch0State;
Serial.print("switch0State= ");
Serial.println(switch0State);
Udp.beginPacket(Udp.relayIP, Udp.remotePort());
Udp.endPacket();
// parse packet
//IPAddress relayIP = (192, 168, 100, 114);
IPAddress DrelayIP = (192, 168, 100, 101);
IPAddress relayIP (192, 168, 100, 103);
//unsigned int remotePort = 5000;
unsigned int remotePort = 9999;
int pwm = 0;
const int switch5 = 5;
const int led2 = 2;
WiFiUDP Udp;
void rxUDP() {
if (packetSize) {
if (len > 0) {
char p[5];
// Udp.write(p); // current value for pwm
// Udp.endPacket();
// Udp.endPacket();
if (packetSize > 0)
Serial.print(":");
case '1': //
break;
case '2': //
break;
case '3': //
break;
case '4': //
break;
case '5': //
break;
case '6': //
break;
case '7': //
break;
case '8': //
break;
pinMode(switch5, INPUT_PULLUP);
Serial.print(".");
Serial.println("");
Serial.print(":");
// Udp.beginPacket("192.168.100.103", 5000);
delay(10);
if ((digitalRead(switch0)) == 0)
Serial.println("turn on");
Udp.beginPacket(relayIP, 5000);
Udp.write("1"); // relay on
Udp.endPacket();
Udp.beginPacket(DrelayIP, 5000); // Desk relay
Udp.endPacket();
if ((digitalRead(switch5)) == 0)
Serial.println("turn off");
Udp.write("2"); // relay off
Udp.endPacket();
Udp.endPacket();
