I have some code that currently builds a webpage to initiate the action via a web page button press. I would like to adapt this code to instead be triggered by some VB script on another pc (on the same network) e.g. by something like...
Dim webClient As New System.Net.WebClient
Dim result As String = webClient.DownloadString("http://IP-of-Ardduino/buttonpress")The micropython I have at the moment is
wifi.setmode(wifi.STATION)
wifi.sta.config("SSID","WiFipassword")
print(wifi.sta.getip())
pin_out = 3
US_TO_MS = 1000
gpio.mode(pin_out, gpio.OUTPUT)
gpio.write(pin_out, gpio.HIGH)
srv=net.createServer(net.TCP)
srv:listen(80,function(conn)
conn:on("receive", function(client,request)
local buf = "";
local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
if(method == nil)then
_, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP");
local _GET = {}
if (vars ~= nil)then
for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do
_GET[k] = v
buf = buf.."<h1> ESP8266 Web Server</h1>";
buf = buf.."<p>GPIO0 <a href=\"?pin=SND\"><button>Send Key</button></a></p>";
local _on,_off = "",""
if(_GET.pin == "SND")then
gpio.write(pin_out, gpio.HIGH);
tmr.delay(200 * US_TO_MS);
gpio.write(pin_out, gpio.LOW);
client:send(buf);
client:close();
collectgarbage();
end)
end)If anyone could help me amend the above micropython code to work like this I would be most grateful.
Alex
