- I selected the "NodeMCU 1.0 (ESP 12-E Module)" under the TOOLS menu,
- I added "http://arduino.esp8266.com/stable/package_esp8266com_index.json" to the preferences section under the FILE menu,
- I installed the CP210X driver for Windows10,
- I attached the USB cable from the ESP8266 module to the computer
When all that is done, the following indications are seen:
- No "port" is displayed in the Windows10 Device Manager (shows COM3 when the Arduino Uno is attached by USB)
- at the bottom of the IDE window, it shows "NodeMCU 1.0 (ESP12-E module), 80 MHz, 115200, 4M (3M SPFFs) on COM3"
- Using the WiFi analyzer on my smartphone shows a strong WiFi signal on channel 1 of the 2.4 GHz spectrum named "AI-THINKER_134034"
Since I am unable to select a "port" in the IDE TOOLS menu, I can't load a sketch, etc.
Please help if you can. Thanks very much.
Skipjack6900
