By QuickFix
#73462 AFAIK the ESP has the modes STA (station), AP (access point) and STA + AP (dual mode).
Since the ESP only has hardware for only one channel/mode, I can imagine that STA + AP uses software for the AP-mode (hence the name "SoftAP"), whilst in the other modes only hardware is used (as either STA or AP).
If my assumption is correct, STA- or AP-mode alone would be fastest/most efficient.
So if you need both modes at the same time, you'll have to accept a little bit speed/efficiency decrease.
But... I'm only guessing here. ;)
By MartinC
#73464
QuickFix wrote:AFAIK the ESP has the modes STA (station), AP (access point) and STA + AP (dual mode).
Just a side comment, I have read on the Espressif forums that if you use the combined STA+AP mode then you can periodically lose connection on the STA side when the AP goes into RF Scanning mode to check for interference levels on adjacent channels (this issue: https://github.com/esp8266/Arduino/issues/1615). For this reason I too would recommend using the dedicated STA or AP modes. In fact I'm not sure when I might need a combined STA+AP mode at all, but I'm sure there must be a reason that it exists...?
